Results 1 to 5 of 5
    removing front wheel is brake caliber OK?
    Juicy 5 and Shimano SLX hydro brakes - if I remove the front wheel for transporting the bike do I need to put something in place of the brake rotor for transportation or are the brake calibers ok?
    Someone told me it was necessary to put something in place of the front rotor or pieces will fall out of the caliber.
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    nothing should fall out but its a good idea to put a shim of some sort between the pads because if something bumps the brake lever you will have to pry the pads apart to get the wheel/rotor back on
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Reputation: vk45de's Avatar
    I never do and mine never fall out. Should be even less likely w/ Shimano since pads are attached with a solid pin. Good job spelling brake right, it's caliper though.
    Thanks everyone. My Purdue education was lacking a little in sbelling.
    You mean Burdue right? OOOO thought you could get away with that one huh?
