Results 1 to 2 of 2
    Oct 2011
    Rebuilding Shimano BL M585 Deore LX master cylinder
    I have a set of these on my 26" HT, they have been good brakes and I don't want to replace them but, my rear brake has begun to leak mineral oil at the lever. I assume a rebuild would fix the issue but I can't find any parts listed anywhere. I seem to remember these were supposed to be the same mechanically as the XT of the era(2005ish), any thoughts as to what I can do to salvage these brakes, thanks in advance.
    Reputation: Wombat's Avatar
    Shimano doesn't list any internal parts for that brake lever: http://techdocs.shimano.com/media/te...9830608737.pdf
    Could it be leaking from the hose? If so try tightening it and if that doesn't work shorten it slightly and put in a new olive.
    If all that fails get another lever. Shimano says all their levers are cross compatible, and you can find them for around $25. Just make sure they have the same style hose fitting (in your case inline rather than banjo).
    Tim
  1. Shimano M785s leaking at Master Cylinder?
    By tangaroo in forum Brake Time
    Last Post: 07-08-2013, 06:32 AM
  2. Leaking Magura master cylinder
    By bad mechanic in forum Brake Time
    Last Post: 07-24-2012, 03:28 PM
  3. Help! Blown master cylinder!
    By CyclesnIPAs in forum Brake Time
    Last Post: 04-03-2012, 07:20 PM
  4. Hope Master Cylinder
    By Enduramil in forum Brake Time
    Last Post: 09-19-2011, 02:26 PM
  5. Master cylinder
    By desrcr in forum Brake Time
    Last Post: 08-17-2011, 12:31 PM
