Results 1 to 5 of 5
    Rep'n the 905
    Jun 2012
    Rear brake just not right, cant get a good lever feel.
    This is my first hydro brake bike ever, so I am new to them but I just cant seem to get that nice beef, strong feel at the lever like I had on my mech disc brake. I shouldnt say I cant, I can by adjusting the knob on the lever but it then causes drag on the rear wheel. I can't seem to find a happy medium. Any suggestions? I have Elixer 7SL's.
    * not sure if it makes a diff but my front brake is amazing. great, strong feel never had a problem with the front.
    Dec 2011
    The most obvious thing I check when this occurs is does the caliper line up with the rotor perfectly? if there is a slight angle in leads to spongy feeling brakes. The old 'squeezing the lever and tightening the caliper bolts' is commonly a cause of this.
    Otherwise - are the pads worn in properly and worn evenly?
    Rep'n the 905
    Jun 2012
    Quote Originally Posted by Uphill=sad View Post
    I'd be pretty shocked if the pads were worn in proper, or evenly. I guess I like to use the rear brake cause the pads seem pretty worn down already and I've only had the bike out in the trails for 3 months or so
    BigGK, get some new pads, give 'er a bleed and as Uphill=sad says, make sure your pads are hitting the rotor evenly. Those things together should definitely take care of the feeling you're getting.
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    I have noticed that a sticky piston will also cause a weird or spongy feel at the lever.
  1. XT M785 Lever Feel Problem
    By JuliusHettig in forum Brake Time
    Last Post: 10-14-2013, 11:30 PM
  2. Lever Play and dead feel
    By icalebkim1 in forum Brake Time
    Last Post: 07-30-2012, 12:15 PM
  3. Switching brake lever? Front/Right Rear/Left
    By HaxEJxuK in forum Brake Time
    Last Post: 09-23-2011, 06:34 PM
  4. code 5s-funny lever feel
    By Uncle Six Pack in forum Brake Time
    Last Post: 08-11-2011, 08:45 PM
  5. XTR 985 lever feel issue.
    By Johnny Chicken Bones in forum Brake Time
    Last Post: 07-10-2011, 10:04 PM
