Results 1 to 2 of 2
    Reputation: telemike's Avatar
    Really sticky piston!
    I'm rebuilding three year old "Elixer 4" calipers. Really a specialized-specific juicy 3 caliper. All of the pistons were quite sticky. Only one came out with the air compressor. None are reusable after I got through with them.
    One piston was especially stuck and couldn't be pryed (carefully) out, aired out, or anything else.
    I finally removed it from the caliper half by grinding the center pyramid (for locating the pad) to a dish shape. I then drilled and used a 6-32 tap to tap the hole in the piston. After screwing in a 6-32 machine screw, I used pliers on the screw to gently rock the piston until it came loose. What a chore! It would have been better to do some periodic cleaning and lubing of the pistons ahead of time.
    The piston was a hard thermoplastic like bakelite. This method worked well when no other method would get the piston out.
    Hi, I got the same problem with my Avid Ultimate Juicy Lever Cylinder!
    First I tried to bleed the brakes from bottom cylinder and wasn't getting anywhere. So I went from top down and was a breeze!., then went to my lever cylinder and was dead so I tried pumping the lever and nothing!! So I decided to dissemble the lever and the piston is stuck!!, I mean really stuck I took w-40 waited and took out the air duster to blow through cylinder and can't get this piston out. I don't know what else to do here.
    Hope you're able to fix and rebuild yours. Can save a lot of money by rebuilding it!!
  1. How Do I Fix a Sticky Piston
    By surfstar1 in forum Brake Time
    Last Post: 05-13-2013, 08:25 PM
  2. XT 775 caliper with sticky piston??
    By S-Works in forum Brake Time
    Last Post: 07-14-2012, 10:49 PM
  3. Sticky piston on SLX m665
    By Bigrocks in forum Brake Time
    Last Post: 06-16-2012, 08:43 PM
  4. Sticky Piston on Magura Marta SL
    By Senor StrongBad in forum Brake Time
    Last Post: 08-29-2011, 11:46 AM
  5. Formula One sticky piston
    By 5H0CK3R in forum Brake Time
    Last Post: 08-07-2011, 06:14 PM
