Results 1 to 3 of 3
    Oct 2013
    Reach adjustment
    G'day. After reading the instructions to bleed Avid Juicy brakes I am confused with one step. That is the reach adjustment. I am aware that this is the 2mm hex screw and will determine the distance between the handlebar and the brake lever. The instructions say to make sure the screw is not too far out that the brake lever bottoms out on the lever body. My question is: What is "too far out"? Do I turn this screw clockwise or anti-clockwise in preparation for bleeding? Cheers.
    Purulento
    I have found a bleed procedure for the Elixirs but the same applies to Juicy models. Check step 7 on pag.25, it says:
    "For models equipped with Reach Adjust, make sure the tip
    of the lever blade is 75-80 mm from the centerline of the
    handlebar...."
    http://cdn.sram.com/cdn/farfuture/bf...nual_rev_b.pdf
    Oct 2013
    Thanks very much mate. Very helpful information.
  1. Zee reach adjustment?
    By chef7734 in forum Brake Time
    Last Post: 03-26-2013, 05:19 PM
  2. 2012 Elixir 7 reach adjustment
    By tailwinds in forum Brake Time
    Last Post: 11-02-2012, 07:54 PM
  3. Louise Reach Adjustment
    By nj0ywatch1np0rn in forum Brake Time
    Last Post: 09-28-2012, 12:39 PM
  4. Brake Lever Reach Adjustment
    By dharel1705 in forum Brake Time
    Last Post: 05-30-2012, 10:56 AM
  5. Elixir CR reach adjustment not working
    By mrankin in forum Brake Time
    Last Post: 12-30-2011, 10:40 PM
