Results 1 to 2 of 2
Thread: Raleigh m50dx
    Sep 2004
    Raleigh m50dx
    My Raleigh M50 DX has the Hayes HMX-2 disc brakes. The wheels are turnable but each time they turn you can hear the brakes rubbing against something and they also keep Squeaking. Can anyone help me out. Thanks!
    P.S.
    Are the Shimano M475 Disc Brakes better then the Hayes HMX-2 disc brakes?
    bi-winning
    Reputation: rkj__'s Avatar
    Quote Originally Posted by wparker
    P.S.
    i am sure the shimanos aren't any worse, but you should be able to adjust your hayes. If i remember correctly the inner pad has no adjustment. am i right? If this is so, you will need to look at the assembly and see which pad is rubbing, because likely it may just be one. If it is the inside pad (with no adjustment) you will need to unbolt the caliper and reposition it. If there is an adjustment knob, give it a few turns to back off the pad a bit. if it is the outside pad, you should be able to adjust this buy the cable, either at the lever or at the caliper. are they new? sometimes the pads just need to wear down a bit. also, your QR levers can have an effect on the centering of the wheel. take note of that. hope some of this helps...
  1. Does anyone remember the Raleigh Tomac Ti?
    By Roostalee in forum Diamondback
    Last Post: 08-27-2004, 11:52 AM
  2. New Bike test ride Report: Raleigh Chopper
    By Mellow Yellow in forum Passion
    Last Post: 05-07-2004, 12:54 PM
  3. New Bike Test Ride Report: Raleigh Chopper
    By Mellow Yellow in forum Clydesdales/Tall Riders
    Last Post: 05-06-2004, 06:16 AM
  4. Specialized vs. Raleigh
    By Akali in forum General Discussion
    Last Post: 02-12-2004, 01:30 PM
  5. Specialized vs. Raleigh M800
    By Akali in forum Bike and Frame discussion
    Last Post: 01-28-2004, 09:13 AM
