Results 1 to 2 of 2
    Reputation: edray's Avatar
    Quickie: Hope and Hayes, together?
    Will Hope Floating rotors, work with the old hayes mag calipers? I do not thickness measurements.. Thanks for the time!
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    As long as the OD is the same there should be no problem, if the rotor OD is slightly larger you may be able to shim to fit.
    Formotion Products
    http://www.formot
