Results 1 to 2 of 2
    quick question - which syringe???
    i want to pick up a couple syringes to bleed my m785 brakes and need to know which size. specifically the tip size in order to fit in the openings.
    thanks
    ...a wiggle theres a way
    Reputation: wiggy's Avatar
    I used 3ml B&D syringes with plastic 'shield' cut off. and then just threaded them into the reservoir.(since they are plastic) on the caliper end i used a 10ml 'walgreens syringe combined with some automotive hose and was able to bleed the brakes successfully.
    good luck
    -joe
