Results 1 to 2 of 2
    Reputation: micstew's Avatar
    Quick question: Center-lock rotor installation
    Add a small amount of grease on the center-lock splines or install the rotors dry? The Shimano docs mention a torque setting but nothing about prep'ing the splines in any way. Thanks. - M
    From what I know, and I do used Centerlock rotors, is that you shouldn't need to grease the splines, put them on dry. If you want more info contact your LBS.
    Anything worth doing is worth overdoing...
    -Ricko, mtbr member
  1. Replies: 9
    Last Post: 04-07-2005, 04:55 AM
  2. What do you use to lock up your bike?
    By LavaPunk in forum General Discussion
    Last Post: 02-06-2005, 01:20 AM
  3. Good info on bike locks.
    By 2melow in forum General Discussion
    Last Post: 02-06-2005, 01:02 AM
  4. Hayes 9 with center lock disc?
    By arch47 in forum Brake Time
    Last Post: 01-29-2005, 09:55 AM
  5. quick headset question (need help)
    By smoofers in forum General Discussion
    Last Post: 09-09-2004, 07:32 PM
