    quick and dirty juicy bleed
    so somebody on here has got their own little shortcuts on the official way to bleed juicy brakes. time to share. sharing is good.
    3 "fiddy" for short
    Reputation: be350ka's Avatar
    Dec 2004
    You are supposed to know everything. Right?
    Meh.
    Reputation: XSL_WiLL's Avatar
    No real shortcuts. But if you bleed it right the first time. If you ever need to bleed it again, you can usually skip the caliper and just bleed from the lever.
    Take your time to degas the fluid. Tap the lines while bleeding. All that good stuff.
    well, in my defense i *DO* know everything. i can recite the exact instructions of a juicy bleed verbatim:
    step 1 - climp up the elephant with a midget on your shoulders.
    step 2 - slide down the elephant's trunk while the midget does a somersault.
    step 3 - do a somersault through the ring of fire with the midget on your back.
    step 4 - the trapeze artist grabs you by the ankles while the midget somersaults onto his shoulders.
    etc. etc.
    also, i do know that it gets pretty aggrivating going through all that every time. i just figured someone had a quicker method.
