Results 1 to 2 of 2
    Go SOLAR...
    Reputation: larlev's Avatar
    question re: Juicy 5's
    I see that juicy 5's are pre-bled ready to go. The question I have is how does a set fit the same on a small or large frame? Surely you have too much line or not enough somewhere. Do you just leave it as is or cut the line to fit?
    Meh.
    Reputation: XSL_WiLL's Avatar
    The stock lines are pretty long. It may be a bit too long on a small frame (unless the hose routing is funky). And there is usually plenty for a large frame (unless the hose routing is funky).
    Some people leave it. Some people cut it to length and rebleed.
    Factory bleeds are not always the best.
