Results 1 to 3 of 3
    Loose Nut Behind d' Wheel
    Reputation: Lucky's Avatar
    Question on older Ultimate L's
    I got tired of the pivot slop in my old SD 2.0 levers, so I scored a pair of Avid Ultimate levers on E-bay. They turned out to be relatively old (late 90's), though still in decent shape and still for v-brakes. They don't have a return spring, which the newer ones do. Are the springs just missing? I looked them over and don't see a place for a spring to connect. Will that make a difference - I'll be using these with Avid disc's. I'm concerned they won't retract all the way if there's any drag in the cable (full housing front and rear), and my brakes may drag.
    Kathy
    Look where you want to go. This is as true in life as it is in mtbiking.
    aka Willy Vanilly
    Reputation: will8250's Avatar
    Aug 2003
    I'm not sure if they're supposed to have a return spring but you could always up the spring tension on the brake caliper itself at the black hex head bolt (like a 2.5 or 3mm..? (never used em myself)).
    Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction.
    E. F. Schumacher
    sXe
    I use the same setup...
    It works great. There never was a return spring in those levers. I also use full housing Flak Jackets, but any quality housing will give good results; no problems with lever return. As the other poster said, dial the return spring at the caliper for the feel you want. Position the lever for easy one-finger braking, as you will rarely need to use two.
  1. Brake response question? and Slider pressure question?
    By Gnar in forum Downhill - Freeride
    Last Post: 09-05-2004, 03:20 PM
  2. Newbie lbs question
    By joshua_msu in forum General Discussion
    Last Post: 03-15-2004, 04:49 PM
  3. Newbie Lbs question
    By joshua_msu in forum Passion
    Last Post: 03-15-2004, 10:13 AM
  4. The Ultimate of Ultimate Riding Tours...
    By bikeCOLORADO in forum Passion
    Last Post: 02-19-2004, 05:29 PM
  5. All Ultimate questions answered here.....
    By 2melow in forum Tooltime
    Last Post: 02-16-2004, 10:34 PM
