Results 1 to 39 of 39
    bt
    bt is offline
    Nov 2007
    Question on how to create a larger pad gap on Formula R1's
    I have some R1's and they have the FCS adjusters on them as well. What I want to accomplish is to have a larger gap between the pads and I was wondering if there are any tricks or inner pieces I could buy to accomplish this?
    bt
    bt is offline
    Nov 2007
    anyone?
    got a long ride, need help
    Commit or eat sh!t
    Reputation: Cable0guy's Avatar
    I ended up getting XTR brakes and selling my R1's for that reason. Formula Ones have the same issue. When I talked to the Formula guys, it was mainly due to the oversized piston. Not much you can do.
    bt
    bt is offline
    Nov 2007
    I was a fraid of that. I have a set of the older style "the ones" and they have a nice gap.
    Glad you warned me a bout the newer style "ones" having the same tight gap issue.
    How are the new xtr brakes in the gap department??
    thanks
    Commit or eat sh!t
    I have 2 sets of older Ones and both have the same tight pad gap issue. The calipers didn't change between the new and older Ones as far as I know. A little bit of pad rub doesn't matter so much on DH bikes. But on a trail bike, I felt like it affected my climbing.
    It has to do with oversized pistons. When the pistons are larger, they don't move as much. Simple physics. And when you put new pads in (re-bleed, pushing the pistons in, and after other tricks), you will get a lot of rubbing until the pads wear in.
    My advice is to true the rotors as much as you can, and drag your brakes until you get some pad wear.
    XTR brakes are awesome. Nice gap, easy to bleed, and great modulation. A little heavier. Best levers that I have tried so far. Better than R1's fo sho.
    bt
    bt is offline
    Nov 2007
    cool. if you ever sell your older ones, let me know.
    Feb 2012
    could you reduce a bit of the oil in the reservoir o the brakes don't expand that much in "idle mode"?
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    I recently went to an older set of Ones, so this may not apply but....the brakes came with very tight spacing, and after my first bleed the spacing was still too tight- I could hardly wrestle the rotor in, and when I did, it woudn't spin.
    I did another bleed axactly per formulas directions, and it completely solved the issue.
    Seems like the trick is to do the bleed with the pads installed, and a rotor in between the pads. With the MC end open, wiggle the rotor to press the pistons back into the caliper. By doing that, I was able to get a perfect bleed, with the pistons flush with the calipers. Also found that hanging the brakes vertically overnight, then pulling air/pushing oil in from the top (mc) (as described in their directions) was the trick to getting a perfect bleed.
    Link to download their bleed directions
    By the way- I had asked formula guys about over/under filling the MC to fine-tune the feel & clearance- they DO NOT suggest this.
    I've also got 3 sets of elixirs, including XO's, and so far I'm liking the formulas MUCH better!
    Commit or eat sh!t
    FM, I tried all that. Even used caliper grease on the seals. I also sent in mine to Formula to have them work their magic. But eventually as the pads wear down, the pistons like to go back to their "natural" spot, which has the rotors rubbing when pads are new.
    Like I said earlier, not much of a problem on DH bikes. If anything helps my slow $ss. But on trail bikes, it is a pain in the behind.
    bt
    bt is offline
    Nov 2007
    i just tried a good bleed and still there is a tight gap.
    ordered up some xtr's.
    hoping the gap is better.
    Feb 2012
    very good choice!
    Do those brakes use seal retracted pistons? If so use the softest pad you can use for your riding. I trail ride and the pistons would creep closer as they were used. They were cycled back and forth without using pad up. Over time I found the seal would slip or work itself up on the piston. When I use soft pads they reset much more often and keep the clearance.
    lean forward
    Commit or eat sh!t
    Quote Originally Posted by bt View Post
    The picture you linked is the XTR "Race" brakes. The "Trail" version has finned pads, and has more power (Servo-wave). The Trail version also has longer levers and is a bit heavier too. I am using the Trail ones with organic pads for better feel.
    Reputation: WR304's Avatar
    This picture shows the pad / rotor gap on my Shimano XTR M988 Trail brakes.
    Love the new 2012 XT brakes
    If having a reasonable pad / rotor gap is important then Hope or Shimano brakes seem to have the largest gaps.
    Don't know if you ever solved your problem or even have the brakes still, but hopefully I can help someone who is having the same problem by posting here. Just got done fiddling with mine and talking to a Formula rep over the phone for an extensive amount of time.
    It is my understanding that the 2013+ model year Formula brakes now have more piston "rollback" to create this larger gap you desire. Word was that they would sell the kit to retrofit to older models so you can get the same pad gap as current model Formula brakes. Also, they work best with Formula rotors as they are ass-hair thinner than most offerings. So using any rotor that is not Formula will cause more pad rub than normal. I am guessing they realized alot of riders reuse their rotors from a previous braking system and that more piston "rollback" would solve it.
    I have 2011 Formula The One's, being ran with Avid rotors. Almost impossible to get no pad rub. I can't hear it when I ride though, and when my bike is on the stand my wheels spin more freely than most of my riding buddies so I am not worried about it. The only chronic issue's with Formula, in my opinion, is that they can be tricky to bleed and that the bleed port o-ring falls out for alot of people. The bleed issue I believe is design related, but with some patience a good bleed can be achieved fairly easily. The o-ring is more of a user error so all in all I would say they are on par with the best in the industry. If pad gap is an issue, buy some Formula rotors, or call them up and see about getting a rollback kit to retrofit to them.
    Reputation: mazspeed's Avatar
    Quote Originally Posted by csermonet View Post
    Thanks for that by the way, I didn't know the formula rotors are thinner. My buddy has a set of ones (begging him to get rid of them) and he did buy the retract kit early this year and still the same problems. It didn't seem to work, but will let him know about the rotors. Thinner rotors are a stop gap to a much bigger problem that they can't seem to get a grasp of, and the fact that you might warp a thin rotor would be a concern to me, maybe or maybe not, I don't know but I am tired of riding with him with those brakes that make more noise than our conversations. Thanks for the update.
    Quote Originally Posted by mazspeed View Post
    I just read a thread from ~2009 that had conflicting information, with many people claiming the Formula rotors are actually thicker than most? I don't know what to believe now in regards to that, I have some digital calipers but don't have several brands to test. Which year The Ones does your buddy have? I have 2011, which I put Goodridge lines on. I also use Avid rotors, and I have never been able to get zero brake drag. I don't really mind that much as it is a DH bike after all, but it is very minimal. When my bike is in the stand you can hear that the pads are making contact with the rotor, but the wheels still spin very freely. Virtually has no effect, and when riding I can't hear it or notice it. I have also owned Hayes and Avid brakes and none of my systems ever had zero drag, and also did not have much of an effect. So in that respect I don't really have a complaint. That being said, if the rollback kit gave me REAL drag free brakes, I might spring on that since its a luxury I have never had haha
    Oct 2012
    The last Formula rotors I worked on were 2mm with a minimum thickness of 1.75 stamped on the side. 2012 bike.
    Car brake systems use the flexibility of the sealing ring to facilitate retraction. That way there is negligible friction and the only theoretical retraction resistance is hydraulic drag. Otherwise, the rubber would get worn out pretty quickly. Car brakes have no return spring other than the rubber seal.
    Obviously, given enough force, the pistons will retract all the way as long as there is somewhere for the fluid to go. But the force to do that is far greater than the puny little return spring. I consider that to be there to keep the pads from rattling and to hold them against the piston; if they were going to retract the piston they would need to be a lot stiffer.
    Maybe bike brakes differ; but my guess is that the amount the brakes retract is limited by the seal design which may be why they tried to fix it with a different seal. I'll admit that getting a Formula brake to not drag is tricky but quite doable. There just isn't any room for error.
    I've had no problems getting zero drag from Hayes and Avid systems so it's just a matter of having straight rotors, good bearings, clean pistons and careful and successful alignment. There's only one straight but an infinite variation of crooked.
    Reputation: sparxlee's Avatar
    Mar 2013
    i was getting drag too, this is what i did maybe it can help?
    took the pads out and spread the calipers apart careful not to scratch or damage anything. then once the calipers were farther apart i re-installed the pads i used two business cards on each side as spacers between the rotor and pads, then i gently squeezed the brakes back into position and with the spacers now the pads are set with no drag!
    three notes:
    1) the first time i unscrewed the high fill point screw (or whatever you call it?) and then pushed the calipers apart while letting the fluid purge back out the screw then tightened it (careful not to let it get any air).
    2) the second time i just simply pressed the calipers apart without letting any fluid out (not sure if thats bad or not???) but this worked fine.
    3) the most important thing i noticed was that even though i was "centering" the pads/assembly while squeezing the brakes and then slowly tightening the housing down, i was still getting slight drag and the culprit was when i tightened the housing down it was getting VERY SLIGHTLY misaligned...so for me i just made sure i could see daylight between the pad and rotor with brake lever un-engaged as i tightened it.
    results are awesome now i havent had pad rub since.
    hope this helps
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    Quote Originally Posted by sparxlee View Post
    three notes:
    hope this helps
    This is an old Hayes brake trick too, the business cards being needed because the early generation Hayes Disk Brakes didn't retract ever I swear. They also popped out if you squeezed the caliper without a disc in it requiring you to rebled the damn things and scrap your ride for the day. Oh and the pads would fallout when you took your bike off the roof rack or when you were changing a flat, without you noticing and then you reassembled your bike, got on rode off, hit the brakes and it would rip your piston out of the brake.
    Glad the business card thing still works and glad brakes have evolved!
    Try this: HTFU
    Mar 2013
    what i found in my experience was that it didnt matter if i bled them...it has to do with space you "set" the pads at when bleeding. so thats why i used a business card (only thing i had to use at the time) as spacers between the pad and rotor and this gave the pads something to "set" themselves against and then when i took the cards out i was left with a sliver of daylight...no rub
    my point is i dont think it has anything to do with what brakes you have but rather the (width of the rotor)+(spacer tool/"business cards" anything to achieve the "gap" you desire)= "DAYLIGHT" or no drag
    Quote Originally Posted by rockcrusher View Post
    I have read of that technique before, never tried it. I'll give it a go and see what happens. I was under the impression that the system worked in such a way that when you remove the cards and pull the brake lever, the pistons would just reset themselves again for the new "pad width". Thus going back to square one.
    Mar 2013
    it worked two different times for me, so i hope it works for you. personally this is something that needs to be explained better or stickied.
    Jan 2005
    Quote Originally Posted by 1niceride View Post
    Do you have an example of the "softer pad" you are referencing?
    Jul 2014
    The front brake went fine, but on the rear the piston won't stay retracted, it just pops right back out when I push it in, so there isn't even enough clearance to get the rotor back in between, not even close.
    maybe too much fluid in master? Maybe some air somewhere?
    lean forward
    Jan 2015
    Hello, anyone ever have a problem with formula rx brakes? replaced pads and the brakes are now super tight< to the point to where the wheel barley turns, I am thinking pistons are not all the way back in? any help?
    thanks mike
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    I think you'll get a better response if you start a new thread titled RX instead of R1
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Quote Originally Posted by motobikemike View Post
    thanks mike
    When you changed your pads, did you retract the pistons?
    Whenever you replace worn out pads you have to retract the pistons to accommodate the extra brake material on the new pads.
    When was the last time you bleeded your brakes?
    I bleed my RX once a year, this way I know that I wont have problems related to bleed problems.
    I'm sure the pistons aren't retracted all the way. You can push them back with a pad spacer like you get with new brakes or carefully push them apart with a screwdriver or something.
    > /dev/null 2&>1
    Feb 2012
    Formula brakes are notoriously biased towards one side. On my r1 and 'the one' brakes, one side drags, no matter how far I push back the pistons. This may be what you are experiencing with your rx.
    To counter this, when centering the brakes and mounting the calipers, center once the normal way, then observe which side is dragging, then loosen the caliper bolts. Insert a single piece of paper between the pad and the disc on the side which is dragging. You are using this to nudge the caliper over a little. Grip the brake and tighten the bolts. If it still drags, try again with a thicker paper, like a business card. That usually does the trick.
    Jan 2015
    push 1 piston in and the other pops out, go back and forth and both wont stay in at the same time, strange
    Jan 2015
    that's the way the levers feel "too much fluid" but don't see how this could be when I have not bled the brakes yet since I bought the bike new
    damned rocks...
    Dec 2014
    Water, DOT fluid is extremely hygroscopic and absorb water from the air through the seals.
    That's why DOT brakes should be bled once a year, not that mineral oil brakes don't should, but in DOT brakes it is more like a need if you want to keep them in perfect brake condition and avoid problems like you are having now.
    Jan 2015
    Hi Aglo,
    the moisture in system sounds right, gonna give it a try and see how it goes, I have heard bleeding the brakes can be a pain, cars are easy, haha thanks for the help
    Jul 2014
    Had the same problem, had to let some fluid out, but did not bleed them. Need a special kit to bleed these brakes, and there are numerous reports of problems attributed to "bad bleeds" (correctable by doing it over).
    damned rocks...
    Dec 2014
    Yeah, bleed Formula brakes for the first time can be a PITA, but after you get the hang of it you can easily bleed them, it just take a couple of times to get the trick.
    Following the instruction provided by formula and watch the videos will help too.
    And you don't need a uber expensive bled kit to bleed them. My kit cost me around 10 and included two syringes, two hoses to attach to the syringes and lever/caliper, a torx key, a par of nitrite gloves and a 100ml DOT fluid bottle.
    Jan 2015
    RX bleed,
    Quote Originally Posted by andytiedye View Post
    Hey Andy, yep he brakes re super easy to bleed, I to pad like 20$ for the bleed kit, old fluid was super milky, so glad I got around to doing that, all started with putting in new brake pads, so now brakes work like new again
    Reputation: pressed001's Avatar
    Jan 2014
    three notes:
    hope this helps
    Worked for me. Thank you.
    Loosening the brake lever top bleed screw while performing the old-pads/screwdriver trick worked to get the calipers all the way in. Attempts to do so without loosening the bleed screw were impossible. I mean, really, impossible. The calipers would not seat entirely. This whole deal started when I replaced the rotors with my favorite Ashima's, and I couldn't get them between the new pads. No matter the force applied, the calipers would not seat entirely. After performing this, the calipers were quickly seated all the way, there is a bit more play in the levers which I prefer, and there is zero rubbing whilst riding.
    Does anyone else just love the sound of the Ashima Airotor ARO-08's? It's like a wonderful bubbling sound whilst braking. It does taper away after some time, nevertheless, great stuff. The Formula sintered metallic pads should prove to be a great combo with these.
