Results 1 to 6 of 6
    Reputation: mrcyrus16's Avatar
    Dec 2011
    Question about the BB7's...
    Good day,
    I've been searching this forum among others and have done enough research that now I'm kinda confused, so I'm hoping I can get a little "guidance"... I currently have a 2012 Giant Talon 2 with the stock DB's (Tektro Aquila) and I'm looking to upgrade the front brakes first.
    I've decided to go with the Avid BB7's and was wondering if going from the 160 to the 180 (I'm about 230lbs) be worth it or will the 160's work just fine? I have the Manitou Tower Expert fork, would the 180's fit?
    Jim
    Drinking rum before 10am makes you a pirate...not an alcoholic...
    At #210, using BB-7's - I notice the difference in both stopping power, and on the rigid SS - fork shudder.
    Vibration is not an issue on a Reba. Oh & yeah, replace the cable/housing with teflon Jagwire - night & day!
    Bicyclochondriac.
    Quote Originally Posted by mrcyrus16 View Post
    Good day,
    I would definitely go with 180. It will make a difference. I would also go with something like Jagwire Ripcord cable/housing.
    Dec 2011
    Thanks guys!
    Jim
    Sent from hell using Tapatalk
    Jim
    WillWorkForTrail
    Jun 2012
    Yes, 180's all the way for the front. When you get to the back, you can keep a 160 there. On the back it's even more crucial to use good cables.
    Dec 2011
    Just ordered the BB7 w/180's, Jagwire Ripcord housing/cable set with new Speed dial 7 levers...can't wait to get them on! Thanks again for helping out!
    Jim
  1. Got my 60$ BB7's!
    By shawnt2012 in forum General Discussion
    Last Post: 05-11-2013, 06:43 PM
  2. Question about Avid's BB7's
    By tracerprix in forum Brake Time
    Last Post: 04-18-2012, 05:56 AM
  3. G3 Rotor with BB7's?
    By gfs69 in forum Brake Time
    Last Post: 01-15-2012, 11:43 PM
  4. BB7's
    By cobba in forum Brake Time
    Last Post: 05-30-2011, 12:30 AM
  5. BB7's!
    By blkcheerio in forum General Discussion
    Last Post: 02-08-2011, 01:55 AM
