Results 1 to 2 of 2
    question about avid juicy 3
    I just replaced my pads when I discoverd that one piston was stuck I was able to get it unstuck and cleaned when I installed my new pads they were rubbing bad the pistons were not going back flush with the calipers so I cracked open the bleed screw and let abou two drops out that let the pistons go back to the caliper face but now I have no lever can I add a little Fluid to fix this and how because when i crack open the set screw fluid comes out.
    Reputation: scooter916's Avatar
    buy the bleed kit and follow the directions
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
