Results 1 to 5 of 5
    Cheesiest
    Reputation: intheways's Avatar
    Putting Rear Avid Disc on Front
    This may be a stupid idea, but I want to try to put my avid rear disc brake on the front. I bought a hayes hmx-1 for the front, but it sucks, so I want to run the rear I bought up front, until I can afford a new one.
    Is this possible?
    Roy
    Roy is offline
    Reputation: Roy's Avatar
    Quote Originally Posted by intheways
    Is this possible?
    Yes, you simply need the standard front caliper cps, and then you just switch them out.
    On MTBR hiatus :(
    Is this possible?
    The Avd and Hyes adapters should be interchangable. You *should* be able to transfer the Avd caliper & CPS washers to the front Hays adapter, and the Hyes caliper to the rear Avd adapter, provided they're both 160mm (or Avd's old 165mm) rotors.
    Cheesiest
    Sweet! I'll see if the Hayes adaptor will work.
    "El Whatever"
    Reputation: Warp's Avatar
    It's a sweet combo indeed...
    The Avd is all about power and the Hayez has decent power but sweet modulation. IMO, you have a winning combo in there. You'd have to spend like 300 bucks for a real upgrade (that would be some high end hydros)
    Check my Site
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. putting Avid Mech rear on front?
    By sargon97 in forum Brake Time
    Last Post: 05-23-2004, 11:06 PM
  3. No power on rear Avid disc
    By Dijridoo in forum Brake Time
    Last Post: 05-12-2004, 06:55 AM
  4. Replies: 14
    Last Post: 04-23-2004, 02:35 PM
  5. No power on rear Avid disc (x-post from Brakes)
    By Dijridoo in forum Singlespeed
    Last Post: 04-21-2004, 06:00 PM
