Results 1 to 9 of 9
Thread: Pulsing Juicy
    Nov 2007
    Pulsing Juicy
    So I have a relatively new (around 250mi ish) 2007 J7. I like the brake fine but when I always light to moderate pressure to cut some speed it pulses. There is no lever feed back it just feels like your on a sine wave. They're going to be bleed soon already but will that solve the problem? I was thinking the rotor is out of true; which it is but not a whole lot. Uneven pad wear? Pads not broken is properly? Any other thoughts?
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    It doesnt take much to cause the lever to pulse from a bad rotor, sounds like you diagnosed your problem.
    http://www.utahmountainbiking.com/fix/diskrotortrue.htm
    Formotion Products
    http://www.formot
    Meh.
    Reputation: XSL_WiLL's Avatar
    Check fastener torque. Check hub/pivot bearings for play. Check spoke tension. Check that the caliper is centered properly. Check the pads for even wear. Proper break-in is pretty crucial.
    Nov 2007
    Quote Originally Posted by dogonfr
    Its pretty significant though, which is why I was leaning away from the rotor ...Nevertheless you know a lot more than me about brakes.
    Okay! Thanks for the list! Although the caliper is pretty center, that's about the only thing I obsess about brakes, centered with no rubs or dings.
    Meh.
    Quote Originally Posted by Renovatio
    Just because it's not rubbing doesn't mean that the caliper is centered and square.
    Also check that the pads aren't grabbing at the arms of the rotor.
    Nov 2007
    I follow avid's instructions by loosing the bolts, pumping it a few times and holding while tightening the bolts...or something like that. Rinse repeat a few times. Is there a better way?
    Jul 2003
    Check for dark spots....
    on the rotor. Just finished with a customer that had the same problem on a set of shimano brakes. Turns out there was a big old finger print on the rotor that misssed being cleaned off. Made a bit of a dark spot where extra pad material had collected and was causing the brake to pulse, no lever feed back or anything else, just a quick pusle as that spot passed through the pads. A light sanding of the rotor and pads and a good cleaning with alcohol solved the problem.
    Good Dirt
    Probably a long shot, but I have a Galfer rotor that varied in thickness by .004". It pulses very noticeably. This may be the problem if your brake has always pulsed. This would not be the problem if it just started.
    It will take a micrometer to measure this small of a variation.
    mbtr member
    Reputation: scottzg's Avatar
    they also pulse if the pad is braking on the rotor tines.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
