Results 1 to 3 of 3
    Bonking ... not feelin' well problems mounting Hayes 9 on pike426
    Swapping a Marzocchi drop off for a pike 426. The IS mounts on the pike seem to be setting further in towards the axle, where as on the marzocchi they are dead center. So the bracket on my hayes right now wont fit between the IS mounts and the roter. Is there another bracket for the Hayes caliper or whats up?
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    I'm not sure if the drop off is one, but marzocchi's 20mm forks use a thicker adapter (or washers) to center the caliper than "regular" adapters.....the pike uses the same adapters as any QR fork
    Meh.
    Reputation: XSL_WiLL's Avatar
    Ditto. Marzocchi is kind of strange in that they offset the tabs on their 20mm thru-axle forks by about 5mm. Fox and Rockshox do not.
