Results 1 to 5 of 5
    Get your freak on!
    ... and if we just ... Problem with Hayes!
    I can't get them to stop rubbing!!!!!!! The rear rotor is warped which I can't seem to get straight, but I also can't see much if any clearence in there any ways.
    Should I push the pistons in or something??! How do I do this?
    You think I should get a spare rotor aswell?! How about the new hayes wavy rotor? Do you know if they are any lighter then the norm?
    BTW both front and back rub, so if you could help me out with the back with the slightly wapred rotor that I can't seem to get stragiht then I could try it on the front.
    Daniel the Dog
    Does it only rub in the rear?
    Quote Originally Posted by bike_freak
    If it only rubs in the rear, then I would say it is rotor warpage related; however, if it is rubbing in the front with a straight rotor then it is set up related. You can pull the pads out and push back gently on the pistons with a plastic tire iron. Then put the pads back in and you should be set.
    Hayes evetually wear out and need a bit of a rebuild. My buddy had problems with his rubbing after 4 years. Universal Cycles rebuilt it and he was set. Also, bleeding is not a bad idea if you have had the brakes for a while.
    My Hayes only rub on really hairy turns because my fork flexes a bit. Oh, they rub a bit when water and muck get stuck in there.
    Good luck,
    Jaybo
    Do It Yourself
    Reputation: Homebrew's Avatar
    Did you check out the Disc Brake FAQ???? Check the upper right hand corner of the page.
    Try this: Flip the bike over. Loosen screws that attach the caliper to the adapter. clamp the brake lever. Tighten caliper screws while still holding lever. Should be mostly rub free now.
    Forked!
    Reputation: DaMtnRider's Avatar
    Use 2 business cards...
    slightly loosen the screws the attch the adapter. slide a business card on each side of the rotor and squeeze the brake lever and retighten. This has helped me in the past. If you have ever clamped the brake without the wheel in place then you may need to push the pistons back in first. Good Luck.
    Any married man should forget his mistakes. There's no use in two people remembering the same thing.
  1. Romic or Swinger 4way coil for 5 Spot
    By Alpenglow in forum Turner
    Last Post: 05-19-2004, 06:20 PM
  2. Time For New Pads on My Hayes Hydros
    By Nim in forum Brake Time
    Last Post: 03-12-2004, 12:00 PM
  3. disk problem?
    By crank in forum Beginner's Corner
    Last Post: 03-02-2004, 03:03 PM
  4. Hayes or Avid for an '01 Fuel 90? (x-post)
    By Spaz in forum Brake Time
    Last Post: 02-10-2004, 08:01 PM
  5. Sugar 3+ Drive Train problem / question HELP!
    By mattstep in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-10-2004, 01:42 PM
