Results 1 to 5 of 5
    Jun 2010
    problem with Avid Elixir CR Hydraulic Disc front
    Avid Elixir CR Hydraulic Disc front was working well after one year .... after that suddently it doesnt work..
    the problem is:
    when I press on the brake handle, it doesnt work... I checked brake pads and they are fine..
    please any solution
    Reputation: Bob12676's Avatar
    Doesn't work?
    Does the handle not move? Does the caliper not squeeze the rotor? or Does the caliper squeeze, but not hard enough to stop the wheel?
    any other details you can think of?
    Jun 2010
    Quote Originally Posted by Bob12676 View Post
    the caliper squeeze but not hard enough to stop the wheel... I adjusted the pads but still it is not hard enough to stop the wheel...
    thank you for your help
    bleed the brake, you have air in the system.
    + 1. If you haven't done it before it might be worth having a shop bleed it for you. There are a couple of youtube videos that will show you the process.
    Quote Originally Posted by DOCRIGID View Post
  1. Avid Elixir CR hydraulic bleeding procedure?....
    By dirtrider7 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-05-2011, 01:27 PM
  2. Avid Elixir CR SL problem
    By Snackie in forum Brake Time
    Last Post: 01-28-2011, 03:20 PM
  3. need help: avid elixir cr problem
    By edwin_eyemd in forum Brake Time
    Last Post: 03-30-2010, 12:19 PM
  4. Avid Elixir CR problem
    By mtbnachos in forum Brake Time
    Last Post: 05-28-2009, 11:02 PM
  5. Avid Mech Disc With Avid Hydraulic Calipers
    By Megashnauzer in forum Brake Time
    Last Post: 12-15-2005, 10:23 AM
