Results 1 to 5 of 5
    The Beast Breathes
    Reputation: mountain_bomber156's Avatar
    Pro X2s or Tech X2s?
    If the Tech lever was meant to replace the Mini Lever, why does Hope still offer the Mini Pro and which one should I get?
    Good luck with that, mister 300-Mile Turn Radius.
    I think I need to Upgrade
    Reputation: AzSpeedfreek's Avatar
    I would have to go with the Tech. There is not that much of a weight difference between the two but the new lever (tech) has recieved amazing reviews with better feel, adjustment, and even better modulation on top of the amazing modulation the minis already had.
    Hack Racer
    Reputation: Cheers!'s Avatar
    if you are going for light XC brakes. Hope is release a new brake...
    2010 Hope Race X2 brakes
    The Beast Breathes
    Quote Originally Posted by Cheers!
    Wow, that lever is SO messed up.
    The Beast Breathes
    Here's my breakdown so far:
    1. I like the lever on the Mini. It has the most curve of any axial brake I've ever seen.
    2. The Techs seem more verstile.
    3. I like the blue color on the Minis, but then again I can tear-down the Techs and home- ano them myself.
    4. I don't care about the weight, even though I should considering the bike they may soon be on.
    5. Clamp on the Tech is much simpler, although this will be a ground-up build which doesn't pay mind to one-piece clamps.
    6. Tech lever is a little flat, but I think I can get over it.
    Thoughts?
