    Save Jesus
    Reputation: beanbag's Avatar
    Preventing sticky pistons?
    This seems to be a common problem with hydraulic brakes, and seems to be caused by dirt getting stuck between the piston and caliper body.
    So I was thinking, how about something like a very thin and flexible concave disk that fits between the piston and brake pad. The diameter of this disk would be larger than the piston. Wouldn't this act like a shield that keeps dirt out of the junction?
    Singapore
    something like a glove? and the caliper is the "wrist"? and the piston as the "finger"?
    Jan 2009
    just like any other disc/caliper setup out there .. you have to do PM to them every so often... pull caliper, pull pads, squeeze pistons out a bit, clean with toothbrush (i use purple power as my cleaner), wash off with water, blow dry, push pistons back in,, put pads back in, go ride..... this is how i do it for all my vehicles....(bikes,motorcycles,cars etc)
    Quote Originally Posted by qkenuf4u
    Just do this every time you change your pads, and you won't have sticky pistons.
    Lead by my Lefty............... right down the trail, no brakes.
