Results 1 to 6 of 6
    Reputation: EGF168's Avatar
    Which post mount rear adaptor (Avid)?
    I did some research and still wasn't sure so does anyone on here know which adaptor is required for a rear post mount frame and calliper with Avid CPS washers and a 185mm rotor?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by EGF168 View Post
    The Avid 185mm post mount bracket, unless your frame is designed to use a 140mm rear rotor on the frame's post mounts.
    Avid Mount Adaptor Front Post 185mm | Buy Online | ChainReactionCycles.com
    mtbtires.com
    Dec 1998
    Post mount needed, not IS.
    mtbtires.com
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    Like Shiggy said.. that's the wrong one.... that's an International Standard not a post mount bracket.. follow Shiggy's link to the right one Thou it's a front mount the rear posts are usually set with the attack angle and such to be the same, but honestly I'd contact the frame manufacture to double check before ordering/trying anything.
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Thanks shiggy, I've given that one a go. I was concerned PM rear would need a different size adaptor for the rear like IS does. Page 50-51 of the Avid parts catalogue is quite helpful.
