Results 1 to 10 of 10
    Post mount brake spacers - Where to find?
    I've seen them in the Avid user manual (shown as "20mm offset (20W)") and they came on my 2011 Epic.
    Rather than a big bulky spacer, they're essentially just a thick "washer" for a lack of better words.
    Anyone know where to find them? I really like the cleaner look.
    Thanks,
    Tim
    Reputation: winter's Avatar
    Not sure if I get what you're asking. Are you looking for something like this...
    If so, it's called a 185mm post adapter and it will require a new longer set of bolts in order to attach your caliper the the post mount on the fork.
    Go on ahead, I'm gonna take a breather.
    B A N N E D
    I think that the OP wants something like this.
    If they are in the Avid Manual then get the part # and ask your LBS to order you some.
    Quote Originally Posted by cobba View Post
    Ah, I see.
    Nope, never seen those for sale before. However, they don't look too complicated, so a trip to the local friendly hardware store should take care of it. Worst case scenario would be machining a set oneself, but that would be too much work for such a simple part.
    I just keep imagining a whole heap of oscillation problems could occur with the two bolts on long stalks.....and without a 'crossbrace' to stiffen them.
    B A N N E D
    If you don't like that then you won't like what's on the following link.
    http://forums.mtbr.com/brake-time/cutting-brake-adapter-save-weight-546442.html
    I was searching for these same spacers. My buddy bought a new Stumpjumper Comp like mine, and his rear caliper came loose and he subsequently lost his spacers. LBS wants to sell him a 140mm rotor instead of fixing it correctly. Any tips on where to get them, or a part number would be helpful.
    Maybe this is the source of the "turkey warble" LOL
    B A N N E D
    Quote Originally Posted by puppster View Post
    Part numbers are in the 2012 Spare Parts Catalogue: http://www.sram.com/service/avid/all
    Get the part number and ask a bike shop to order them for you if you can't find any online sellers.
    That's awesome. Thank you for the help.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Uhhh, time to find a new bike shop.
