Results 1 to 8 of 8
Thread: post mount
    post mount
    I. Am ordering a 2006 marzocchi all mountain sl. It has 6 inch post mount what do i need to run my 180 mm shimanos on it?
    Meh.
    Reputation: XSL_WiLL's Avatar
    Depends which Shimanos you have. Are they IS mount caliper or post mount calipers?
    You'll need the appropriate adapter (match the caliper type and post mount fork) to upsize 20mm.
    they are post on adapters for IS. They should bolt on, but it is a 6 inch post and they are like 7 so do I just put spacers and longer screws?
    ...idios...
    Reputation: SteveUK's Avatar
    Have you tried searching on the intrawebs? (looky, you'll probably be able to get those in the Americas, too)
    Diogenes
    Meh.
    You use an ADAPTER (as previously mentioned).
    I found these: http://cgi.ebay.com/Disc-Brake-Adapt...QQcmdZViewItem
    they are exactly what i am looking for
    they are just longer screws. Will they hold? i could not find any actual brackets. at lest not for shimanoes
    Meh.
    Have your shop order it from their distributor.
    SM-MA-F180 P/P
    BTI part #: SH-65582
    vendor part #: ISMMAF180PPA (SAC)
    rotor size: 180mm
    caliper: 74mm
    mount: 74mm
    fit: PM forks
    alt code: SM-MA-F180 P/P
