Results 1 to 6 of 6
Thread: IS to Post
    VIP
    IS to Post
    Just bought a set of 09 sids with post mount, but since my 07 xtr disc were on an old (06)set of IS mount sids I seem to need an 160mm IS to post mount adaptor but can't seem to find one? Why on earth is this?,
    I found this http://www.chainreactioncycles.com/M...?ModelID=13744
    Shimano adaptor to mount a 51mm international standard caliper to a 74mm post mount fork to accomodate a 170mm disc.
    but considering the xtr disc doesn't even seem to come in 170mm it'd be pretty useless.
    Anyone care to shed some light on this please? Am I missing something obvious?
    Meh.
    Reputation: XSL_WiLL's Avatar
    The adapter adds height to the assembly, so you have to use a larger rotor to get the proper pad contact.
    There are some old 6 bolt 170mm Shimano rotors running around.
    How about buying a 180mm rotor (more common) and using a stack of washers, probably about 5-6mm high, under the adapter?
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Quote Originally Posted by standard3x
    there are adapters for that..... Shimano only makes the 170mm adapter, but Hope, for instance, does make a +20mm adapter to use a 180mm rotor
    http://www.chainreactioncycles.com/M...?ModelID=13735
    ditto..
    on CRC you can find both the 170mm rotor and adapter
    VIP
    Cheers people!
