Results 1 to 7 of 7
    Is it possible to downsize the rotors?
    So, I have a bike with IS/IS brake mounts, and brakes that also come with IS mounts. No problems there.
    However, the brakes are meant for 180 front/160 rear rotors and that is how it works without any adaptors. But I'm fairly lightweight (60ish lbs) and I don't need rotors that big for XC. So, I know I could easily use adaptors to go up a size or two, but is it at all possible to use smaller rotors on this setup or would it require a whole new set of brakes?
    I doubt it if its IS-IS. However, I have seen this...someone flipped a 203mm IS to Post adapter upside down for 140mm action.
    Mosaic Flipped A 203mm Brake Caliper Adapter Upside Down For Use With A 140mm Front Rotor. Photos | Cyclingnews.com.
    Really though, just try the 180s and 160s and avoid the hassle. I doubt you'll have a problem with too much brake.
    Re: Is it possible to downsize the rotors?
    Thanks for the reply! That's what I thought, but I wanted to make sure that there wasn't some piece of information missing that would make this a simple and straightforward swap.
    B A N N E D
    Quote Originally Posted by discohospital View Post
    I'd say that you're extremely lightweight.
    Gosh, my bad. My brain farted mid-kg to lbs conversion
    Reputation: honns's Avatar
    I'm similarly lightweight (60kg/130 lbs) and even I enjoy the benefits of 180 up front. Give it a try, I doubt you'll find you are over-braked. (180/160 on my XC bike, 180/180 on my full suspension bike).
    Oh yeah, if you're 60 kg (like me) 180/160 is fine. That's what I run currently although I'm changing to 203/180 cause I like aggressive brakes and also for aesthetics.
  1. Replies: 14
    Last Post: 04-24-2017, 12:30 PM
  2. Ice Tech rotors vs HS1 rotors
    By shoresnapper in forum Brake Time
    Last Post: 07-27-2014, 12:10 PM
  3. Downsize 29er frame?
    By kuotadriver in forum 29er Bikes
    Last Post: 08-23-2013, 04:14 AM
  4. Replies: 2
    Last Post: 03-26-2013, 05:31 AM
  5. downsize rp23 XV to standard vol. CTD for firmer ride??
    By Woodsy in forum Shocks and Suspension
    Last Post: 09-06-2012, 04:12 AM
