Results 1 to 5 of 5
    251 is offline
    Reputation: 251's Avatar
    Polished: Just Because
    I swapped my 160mm rear rotor for a 140mm and didn't like the adapter. So, with a little oven cleaner and a lot of sanding and polishing...
    Dave
    Reputation: rustybkr's Avatar
    Re: Polished: Just Because
    Looks good
    Plays with tools
    Reputation: customfab's Avatar
    Did you clear coat it or are you going to do that a couple times a year?
    251 is offline
    Neither. I went through a similar polishing process with the cranks on my 29er in December 2011, and they look much the same now as they did then. Worst case, the adapter's finish will end up somewhere between the polished caliper and the blasted Ti frame.
    Dave
    reading comprehension wat
    Reputation: dv8xin's Avatar
    Mar 2013
    Someone call the galvanic corrosion police
    I like to jump to conclusions, oversimplify, gossip, and participate in popularity polls.
  1. SLX Cranks - DeAno'd and polished
    By ADDam in forum Shimano
    Last Post: 08-30-2017, 01:36 PM
  2. polished aluminum clearcoat?
    By s4gobabygo in forum Frame Building
    Last Post: 12-17-2012, 02:03 PM
  3. Anyone polished a 6.6 frame?
    By deesta in forum Intense
    Last Post: 11-07-2012, 11:46 AM
  4. Polished Stylo 1.1's
    By Crosstown Stew in forum Singlespeed
    Last Post: 06-09-2011, 02:44 PM
  5. Polished Cantilevers
    By jasevr4 in forum Brake Time
    Last Post: 06-03-2011, 07:06 PM
