Results 1 to 5 of 5
    IS or PM adapters for Formula
    I am considering changing over to Formula Oro brakes since my Shimano XTRs have failed How do I know if I need IS or PM adapters? Can I use the XTR rotors with the Formula calipers?
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    the adapters you need depend in the fork you have. (the rear should be IS )
    shimano rotors usually have a very narrow braking track (except for Deores which are a bit wider), so I would recommend you use Formula's rotors.
    The fork is a Manitou Skareb Elite. The frame is a Titus Racer-X.
    the skareb is a PM fork, if you will use a 160mm rotor you will need no adapter in the front, if you go bigger you will need a PM-to-PM adapter.
    You will need an PM-to-IS adapter for the rear anyhow, just get the one that matches the rotor size you want.
    mnt bike laws of physics
    Reputation: yogiprophet's Avatar
    XTR to Oro's
    I was thinking of making the same switch and was also wondering about the rotor compatability. The Oro rotors appear to have a very narrow braking track as does the XTR's. Does anyone know for sure about the compatability?
