Hi all i've recently just bought my first full suspnsion bike and it came with some shimano M485s but after a problem with these i've had these replaced with shimano Br-m535's. They originaly came with resin pads but would like to put some sintered pads on instead. I've looked up that the calipers can have sintered pads fitted. The problem is that the replacement brakes didn't come with a new disc rotor and on the rotor it says that you should only use resin pads. Do you think i would be able to use sintered pads or would these ruin the disc rotor? for all i know it could be the same for both sets of calipers.
Dan
