    Upset Please help,how do I get my Shimano xt disc brakes (756) to stop howling??!!
    I have tried everything, I've aligned, re-aligned,sanded the pads, sanded the rotors and they still howl.
    Any help out there?
    Thanks, -Tree
    Reputation: Wombat's Avatar
    Quote Originally Posted by Tree
    Any help out there?
    Thanks, -Tree
    Perhaps try swapping pads (front to rear) or getting some new pads with a different compound to what you have now.
    Wombat
    Reputation: mtbykr's Avatar
    Good Luck
    I had the same problem with mine (older style from 2 years ago) and no matter what i did or the lbs did, nothing would fix it. i ended up selling them and going to avid mech. sad because they worked great--just way to loud!
    Good Luck
    The nine most terrifying words in the English language are, 'I'm from the government and I'm here to help.' --Ronald Reagan
    "El Whatever"
    Reputation: Warp's Avatar
    Some people use some copper compound between the brake pads and pistons which is supposed to dampen vibrations which is what noise is. Had you tried swap pad compound?? Going from Semimetallic to Sintered or the another way around may be the solution.
    Check my Site
  1. Shimano XT disc brakes - Is this possible?
    By Earthdog in forum Brake Time
    Last Post: 11-05-2004, 03:51 PM
  2. Shimano XT vs. XTR disc brakes?
    By frank daleview in forum Brake Time
    Last Post: 06-09-2004, 10:46 AM
  3. SJ 04 XT Disc Brakes or XTR
    By Steve Eungblut in forum Specialized
    Last Post: 04-14-2004, 12:05 AM
  4. shimano xt disc ??'s
    By fl jay in forum Brake Time
    Last Post: 04-02-2004, 07:10 PM
  5. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
