Results 1 to 3 of 3
    Reputation: Mo$ey's Avatar
    Pauls love levers and Jagwire cables issue
    I just got a set of pauls love levers to replace the speed dial 7's on my ride. My issue is that the cable cap wont fit into the adjuster on the paul lever.
    Whats my best option, drill a slightly bigger bore in the barrel adjuster or go to my lbs and see if there is a slightly smaller cable cap that will be big enough to fit over the cable housing and small enough to fit in the barrel adjuster?
    Thanks,
    True North SS 29'er
    True North Road Rocket
    Spec SJ HT baby hauler
    Reputation: fixbikeguy's Avatar
    Don't drill the adjuster as it is more expensive than the cable. Go to your LBS and sort it out.
    LBS had tapered caps, problem solved
    True North SS 29'er
