Results 1 to 7 of 7
    MTBR Member
    Reputation: ncfisherman's Avatar
    Paging JUDE@Magura - Brake adapter Q
    Hello MTBR -
    I am trying to identify the Magura brake adapter I will need for my Magura Marta SL's - older model Marta's w/ IS caliper. I'll be mounting that caliper to a Post Mount fork and will be using a 180mm rotor....having a tough time identifying the proper QM # that I will need.
    Thanks for any help.
    DGB
    DGB is offline
    If this is the guy you're looking for it's adapter #16.
    Can be seen here - http://www.magura.com/en/products/ol...cessories.html
    Click on the photo for a description of its function.
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    Different one, thats for an IS fork. You need a #3 I think. You may have to go up to 203mm too...
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
    DGB
    DGB is offline
    I misread that - sorry!!
    Noah is correct, you need #3.
    DGB
    DGB is offline
    MTBR Member
    Thanks for the replys - having trouble finding number 3. A lot of online retailers state that they don't stock 51mm caliper adapters.
    MTBR Member
    NM - got it sorted out. Thanks for the help.
