    Riding free's the mind
    Pads for old XT V-brakes
    Anyone know if replacement pads currently available are compatible with old XT V-brakes circa 1996-97? Haven't had to replace them till now!
    Question to a custom frame builder..."So what makes your bikes climb better?"....his answer, "Uh, your legs?"
    rolling in the greens
    Reputation: vermont's Avatar
    Take em to the LBS
    I am assuming you are talking about the cartridge style where there is pin holding in the rubber part of the pad...pull the pin and slide out the pad...take it to you LBS.
    Yup
    Quote Originally Posted by vermont
    Yup, this is the type. I try to avoid the LBS, but I guess I can ask for advice. Wonder if the replacements for the current XT Vbrakes pads will work on the old ones?
    Cartridge pads are cartridge pads. They bolt on like block pads, and you don't re-adjust when you're replacing the inserts. Online stores will carry the inserts, my personal fave is the koolstop dual compound. I find them to be much nicer than the shimano stuff, but they'll still fit in the pad holder.
  1. Shimano XT disc brakes - Is this possible?
    By Earthdog in forum Brake Time
    Last Post: 11-05-2004, 03:51 PM
  2. Mineral oil spilled on Shimano XT pads and rotor
    By Dave99 in forum Brake Time
    Last Post: 07-20-2004, 08:00 AM
  3. deore discs?
    By xisaacx in forum Brake Time
    Last Post: 07-06-2004, 03:44 PM
  4. Tuning up XTR disc brakes - pads etc. ??
    By rpbt in forum Brake Time
    Last Post: 06-05-2004, 09:26 AM
  5. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
