Results 1 to 3 of 3
    Reputation: Hellbound's Avatar
    Ordering the right brake components
    I have the Formula oro K24 brakes and just want to make sure I'm ordering the right adapters. They are going on my Heckler with a Pike 454 coil u turn fork. I notice there are quite a few different versions for the adapters. I'm putting a 200mm rotor on the front and a 180mm rotor on the rear. For the front do I need to order the "51mm Is QR" version? I believe that's what I read on the specs for the pike. Now which Formula rear adapter for the 180mm rotor do I need to order for my 08 Heckler? Thanks in advance.
    Explorer in the further regions of experience. Demons to some, angels to others.
    Nevermind I figured it out. It was the Is term throwing me off and I just measured the 2 holes in the back to figure out what size I will need which is the Is 51mm. Thanks anyway.
    Oct 2007
    "IS" means international standard, the 51mm tabs. the 74 (? 70 something) is post mount like manitou.
