Results 1 to 3 of 3
    Sep 2004
    One Resin, One Metal pad in XTR's??????
    One Resin, One Metal pad in XTR's?????? Why would I want to do this? Why would I not want to do this?
    (aka SS_MB-7)
    Reputation: 1speed_Mike's Avatar
    Quote Originally Posted by Beowulf
    Yep, I used one of each pad per caliper when I was using my XTR/XTs this time last year....worked great and I never had any issues! You get the benefits of both pad compounds in one caliper. Plus, by mixing them up, you actually get an extra set of pads.
    Ride Hard,
    Mike B. (MCM# 7.77)
    http://www.one-speed.com
    Reputation: fallzboater's Avatar
    Same here.
    Quote Originally Posted by 1speed_Mike
    One resin, one metal pad in each caliper. You need to be careful with wheel insertion using the resin pads, though. I trashed one by forcing the rear wheel in without being perfectly aligned. The outer edge of the rotor can tear up resin pads.
    -David
  1. avid mech disc pads
    By GaHeckler in forum Brake Time
    Last Post: 02-25-2005, 11:16 AM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. Hayes Pad Metal Clips-Can You Buy Them??
    By cohenfive in forum Brake Time
    Last Post: 09-14-2004, 05:35 PM
  4. Avid pad wear & non Avid pad retention?
    By keen in forum Brake Time
    Last Post: 07-05-2004, 02:10 PM
  5. metal vs. resin replacement pads
    By beekeeper357 in forum Brake Time
    Last Post: 02-14-2004, 03:55 PM
