    One Bike - Multiple Disc Wheelsets
    How do you accomodate multiple disc wheelsets on one bike? It is a huge pain in the ass to re-shim the calipers each time. Does anyone make rotor shims?
    TranceX Rider
    Reputation: Onie's Avatar
    Caution;  Merge;  Workers Ahead! XT WH-M765 & XTR WH-M975 discs
    Since I've started running tubeless for about 3 years already (FWIW, it's a pain in the arse changing tires too often) so I decided my kung fu style would be better off with 2 wheelsets -- Shimano CL as well as the rotors. No need to re-shim. Zero problems, AFAIK.
    But a couple weeks ago, I tried installing those WW alligator rotors using its own CL adapters I've got but like what you've aired here, "It is a huge pain in the ass to re-shim the calipers each time". So, I reverted to CL again. Zilch issues re: re-shimming... Then I'm saving up for my project wheelset so I could use those WW rotors again without the weight penalties of those CL adapters & the re-shimming issues.
    No brainier!
    HTH.
    Quote Originally Posted by jcatienza
    There was no need to scare potential buyers and burn bridges "buddy"
    Tell me now, what's Product testing all bout then?
    mmm
    Reputation: timehoc's Avatar
    ↑ ↑ ↓ ↓ ← → ← → B A Select Start
    You rock timehoc. Just ordered a set.
