Old Magura maintenance/inspection
Hello everybody! I hope all is well!
I am writing to see if anybody still uses magura rim brakes.
Mine still work well so I don't really want to fix whats not broken.
I keep my bikes in top condition but considering the age of the brakes I started to wonder what problems COULD arrise, and what parts I might inspect.
Thanks for any input.
Keith
Here's a link that might be of some use to you.
The magura rim brakes are still produced today - long live the HS33!
Parts etc should still be available through Magura (link provided by cobba)
Hi Keith and thanks for riding the old standard from Magura.
We make more HS brakes today than any of our other disc models, by far!
OEM spec in Europe is strong and solid and found on commuters, trekking and panniered bikes so we make ALOT of these brakes still today.
There are plenty parts and pieces available (not that you would ever need anything aside from pads) and aside from the obvious, rim issues and such, no reason to change really.
It is normal for us to see rim brakes that go 10 years plus without servicing (aside from pad changes!)
Enjoy!
I recommend changing the oil. A while ago I serviced HS33 which were 8-9 years old, always stored in unheated shed (+30C to -35C) and never serviced. They worked quite ok but the oil had turned into gray sludge - after oil change they work good as new and I expect to get still several years of use out of them.
P.S. They are also excellent brakes for kids bikes as they require only a little force and are easy to modulate.
- You may not post replies
- You may not edit your posts
Forum Rules
