Results 1 to 3 of 3
    Reputation: Urnicus's Avatar
    Old bike - Y brake to V brake conversion HELP??
    Ok, I bought an old bike (Specialized Stumpjumper) on the cheap. It had center-pull brakes on it.
    I bought some Avid Single Digit 5s and put them on.
    The problem is there is way to much play in the brake lever.
    I have tried all the combinations of spacing for the pads and tweaked with just about everything that can be adjusted and have had no luck.
    There is not a lot of space between the rim and the pads.
    The levers are OLD Shimano XT STI.
    Any suggestions??
    All I can think is that the levers pull a different length then V-brake levers?
    Retrograde Customs
    Reputation: dansjustchillin's Avatar
    V brake levers pull differently than canti levers. I recomend the levers that match your brakes. avid makes some nice stuff.
    Retrograde Customs
    thanks, picked up some XT integrated shifter and levers.
