Results 1 to 10 of 10
    is it ok to use Finish Line mineral oil?
    Hi...
    After looking at some LBS I realized that the Finish Line mineral oil is cheaper as the LITTLE shimano bottle...So, I want to know if using the finish line mineral oil I`ll avoiding the warranty of my brakes or if it`s just the same stuff as the what shimano sells for a RIDICULOUS price..?
    If there`s people with more than 6-9 months running finish line oil please feel free to share your experiences here...
    thanks!!
    bye
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    I've been using Finish line mineral oil for over a year with no problems on my Shimano Saints. I just had to re-bleed my '08 XT brakes because I had to cut the lines shorter, and I used the finish line Mineral Oil on those also.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    You can go to the local moto shop & buy the mineral fluid also, KTM uses mineral.
    Formotion Products
    http://www.formot
    Reputation: itsdoable's Avatar
    Magura used to recommend Finishline 5wt when thier own stuff wasn't available in the US. It´ll work fine, but it will void the warrenttee...
    Vaginatarian
    ive been using it for 3 months, no problems and I sent back a caliper and got it replaced by shimano so I dont think its a warranty issue for them
    Kosher Princess
    Reputation: Natalie Portman's Avatar
    Good job!
    This is what I choose to run in my lines, no problems, inexpensive, awesome!
    http://www.walgreens.com/store/produ...606&id=prod606
    Jan 2005
    Quote Originally Posted by Natalie Portman
    Leaky Saints
    Formotion Products
    http://www.formot
    Why did you send it back to shimano?...oil-seal issues?
    Quote Originally Posted by dogonfr
    Drug Store mineral oil, as long as it is pure, is fine. Magura (again) used to recommend using it for emergencies, when you did not have access to the right stuff. Re-flush with the right stuff when you get it. The main issue is the viscosity, drug store mineral oil is usually a lot thicker than the hydraulic grade used in bike brakes.
    Nov 2007
    not to mention you can drink it if your a bit clogged up......just remember,keep the trails clean
