Results 1 to 5 of 5
    Sep 2013
    Oil on my disk brakes. How do I clean it?
    So I got a little oil on my rear disk brake from when I was lubricating my chain. My bike stops. But it takes alot longer. Don't feel safe for the mountain .. Does any one know what I can put to clean it?
    RAKC
    Reputation: tigris99's Avatar
    Re: Oil on my disk brakes. How do I clean it?
    First thing is if u get it on there clean it before u ride, cause now ur rear pads are contaminated and good chance they'll have to be replaced. Second is soap and water then wipe off with alcohol pad or spray off with automotive brake parts cleaner.
    How did u manage to get chain lube clr on the other side of ur bike?
    Sent from my HTC Sensation Z710e using Tapatalk 2
    Sep 2013
    I used a spray lube. My mistake 😫. I think I'm just going to replace them. What do the brakes run?
    Sep 2013
    I did ride the bike for like 5 miles. After I noticed the slow stopping
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    Clean the rotor with ispropyl alcohol and flame the pads. Use a torch or a gas burner until the oils burns aways (smoking stops).
  1. Replacing brakes with disk brakes, univega ds900
    By thundercat in forum Brake Time
    Last Post: 03-30-2015, 01:44 PM
  2. Replies: 0
    Last Post: 07-25-2013, 08:14 PM
  3. Replies: 51
    Last Post: 06-05-2012, 01:07 AM
  4. Replies: 9
    Last Post: 02-21-2012, 07:38 PM
  5. a deal on disk brakes- does anyone have a lead on a set of XC brakes?
    By grouan in forum Where are the Best Deals?
    Last Post: 02-08-2012, 01:16 PM
