Results 1 to 3 of 3
    o7 hardrock disc brake conversion???
    i have an 07 specialized hardrock ani i want to cinvert the rear brake to a mechanical disk brake . WHat parts do i need?do i need a new hub or is there something i can pout on the ol one?
    MTBR Demi-God
    If the HR came with V-brakes, then most likely you will need a hub that is compatible with 6-bolt/centerlock rotors. Check to see if your hub already has mounting braces for the rotors or not. Other than that, you just need to obvious- calipers, levers, housing, cable/fluid.
    "Winners never quit. Quitters never win. But those who never win and never quit are idiots."
    Meh.
    Reputation: XSL_WiLL's Avatar
    Yes, you do need a disc hub. Most people go to a disc up front... Most of your stopping power comes from the front end and a disc offers more control
