Is this normal?? Magura louise bat Question
The pads seem to be making contact on the rotors arms a little bit.
i have the sl drilled rotors wich are 160mm. the adaptors are is to p/m 160mm adaptors
Normal. See the other thread of STORM SL rotors - you can see the wear. The rotors are equal thickness throughout, doesn't matter. Alignment on the BAT's are the key (caliper alignment) which are those two M8 or M10 bolts.
- You may not post replies
- You may not edit your posts
Forum Rules
