Results 1 to 3 of 3
    Jan 2005
    Noobie Avid BB7 Rotor size question..
    Ok, I did a big search before posting this simple question...it's late so this might be a dumber question than it seems.
    Ebay has a ton of new Avid BB7 160mm full sets for cheap. However, I would want to run bigger rotors.
    Would these same calipers as they are work with a larger rotor or would I need something (besides the rotor) that comes with the 160mm set to go bigger?
    You will need the new rotors and the new mounting brackets for front and rear. I think there are difference between mounting bracket sizes, so make sure to get the avid mounting brackets.
    Jan 2005
    Thanks.
    Lesson learned - Might as well just get the package with the rotor size you want, it costs more to get a new rotor and mounting bracket. (I shouldn't be such a penny pencher, the full set is only $140...)
  1. Quasi official info: Avid BB5 vs BB7 discs...
    By Speedub.Nate in forum Brake Time
    Last Post: 05-18-2005, 06:31 PM
  2. manitou black fork with avid BB7 203mm
    By ilikepinkbikes in forum Downhill - Freeride
    Last Post: 12-25-2004, 12:03 AM
  3. Replies: 3
    Last Post: 07-01-2004, 11:36 AM
  4. Avid pad wear question
    By rpet in forum Brake Time
    Last Post: 03-14-2004, 06:43 AM
  5. AVID mech disc brake question, on a SS....
    By hu-man in forum Singlespeed
    Last Post: 03-07-2004, 10:48 PM
