Results 1 to 3 of 3
    Reputation: MikeDee's Avatar
    Noisy Hayes HFX-9
    Now that I've sorted out the pad rubbing problem, my back brake is noisy. It isn't a pad squeal, but more like the rotor is vibrating. I can feel it in the seat. I tried different pads, but the same problem persists.
    Custom User Title
    Reputation: dpdsurf's Avatar
    Is it a vibration when you are not applying the brakes? If so it's likely a caliper alignment issue. Keep fine tuning the alignment.
    I do this by flipping the bike upside down.
    Losen up the mounting bolts on the caliper.
    Apply the brake to get started with the alignment proces.
    Then slowly turn the wheel and carefully move the caliper until the wheel spins with no rubbing sound. This can take a little while and sometimes you need to move the caliper at the top or bottom bolt only.
    Tighten the bolts in an alternating pattern while hold the caliper until they are both tight. This helps to keep the caliper from moving.
    Quote Originally Posted by dpdsurf
    No, the pads don't rub.
  1. Hayes HFX 9 XC's vs Avid Mechs
    By Max99 in forum Brake Time
    Last Post: 01-04-2005, 03:10 PM
  2. Hayes HFX -9 Carbon
    By freeriderB in forum Downhill - Freeride
    Last Post: 01-04-2005, 06:15 AM
  3. Enduro Owners Hayes HFX 9 or Juicy 7's?
    By CCRiderKY in forum Specialized
    Last Post: 07-20-2004, 01:27 AM
  4. Hayes HFX 9
    By opticals in forum Brake Time
    Last Post: 06-25-2004, 03:55 AM
  5. Hayes HFX 9 - HD any good?
    Last Post: 03-31-2004, 11:12 AM
