Results 1 to 3 of 3
    newbie old school question avid bb7 and white brothers 29er bw 1.0
    Howdy. I'm finally giving in and going disc brakes. I have a bb7 trying to mount on a white brothers bw 1.0 from 04. issue seems to be that the disc brake mechanism uses 5mm bolts while the disc brake mount in the white brothers is 6mm. I have two of these forks and they are both the same. Incompatible or am I missing something. Thanks old timers!!!
    John Voss
    Miami FL
    B A N N E D
    If it's a PM fork then just get a rat tail file and make the holes in the brake caliper and in the cps washers a bit bigger.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by jvossman View Post
    John Voss
    Miami FL
    Normal IS mounts on both the fork and brake bracket, and both use M6 bolts.
    The only 5mm bolt on the BB7 is the cable anchor.
    Do not need an "old timer" for 2004 and it is far from "old school".
    mtbtires.com
  1. White Brothers Loop 29er Forks
    By Deuce9er in forum 29er Components
    Last Post: 01-21-2016, 02:42 PM
  2. Replies: 9
    Last Post: 04-04-2013, 03:02 PM
  3. Replies: 0
    Last Post: 07-30-2012, 05:14 PM
  4. White Brothers Loop for 29er Single Speed Hardtail?
    By mdavenpo2000 in forum 29er Components
    Last Post: 05-02-2012, 08:51 PM
  5. Spam: White Brothers Magic 110 29er suspension fork
    By appleSSeed in forum 29er Bikes
    Last Post: 10-05-2011, 03:05 PM
