Results 1 to 5 of 5
    Newbie Disk Brake Questions
    Hi
    I am not an experienced disk brake person. I have just installed a new front Avid Juicy 7 Carbon system. All was fine with the provided 160mm rotor but I have just fitted a new 185mm rotor and the pads now rub. The rotor is and avid rotor and im running avid pads. It only rubs a little but it does rub. The pad wear adjustment does not fix the problem. Any ideas on how to fix it?
    2nd problem. The Lever pad wear adjustment has to be set to maximum to make the brakes work. If I back it off the lever pulls all the way to the handle bar and does not full engage the pads. This is with new pads installed. Does this mean it needs more oil? can I use any oil? Will it need bleeding?
    kev
    Reputation: Teebird's Avatar
    I'm assuming you used a new adapter for 185mm rotors on the caliper when you changed the rotor size?
    2016 Pivot Mach 429 Trail, XT/XTR 1x Build Kit
    Yes, I put the correct adapter on. It only rubs a little, I wondered if this was normal until the pads wore down?
    New pads rubbing is not normal. You probably need to spread the pads farther apart (they will reset to the correct spacing when you use them) and align the caliper.
    FYI...Juicy 7's do not have a "pad wear adjustment" knob. The knob adjusts the point in the lever travel where you feel the brakes engage. It does not move the pads.
    "2nd problem"...You need to bleed the brake. This requires an Avid bleed kit and it comes with the DOT 5.1 brake fluid needed. Juicy 7's do not use oil.
    I suggest you take it to your lbs and have them do the work.
    Thanks.
