Results 1 to 3 of 3
    Sep 2013
    Newbie - Crossmax Disc - 6-bolt
    Hello, newbie here :-). I purchased a used bike that had a set of Mavic Crossmax SLR wheels on it and both front and rear have CenterLock discs on it. My question is, what is the best option for me to swap these CL discs over to 6-bolt pattern discs? Thanks, Blake
    What you need is a centerlock adapter: https://www.google.com/search?q=cent...&bih=825&dpr=1
    Feb 2013
    Center lock disks have some advantages over traditional 6 bolt such as easier removal and installation and they are less likely to loosen up or strip out like Torx bolts. If the rotors you have are in good shape I'd keep what you have. You might want to keep one adapter on hand for emergencies, that way you can throw any rotor on there in a pinch.
  1. Replies: 2
    Last Post: 06-13-2012, 05:08 PM
  2. Crossmax ST rear convert to 10mm through bolt?
    By schlim in forum Wheels and Tires
    Last Post: 05-02-2012, 12:08 AM
  3. 2011 Mavic Crossmax SLR Disc Wheelset $699 and more
    By FireLikeIYA in forum Where are the Best Deals?
    Last Post: 09-02-2011, 08:48 PM
  4. Mavic Crossmax SLR Disc. Build that's comparable less $?
    By Scottyman in forum Wheels and Tires
    Last Post: 05-14-2011, 01:16 PM
  5. Crossmax ST Disc (Center Lock) on my SS?
    By Captain Picky in forum Wheels and Tires
    Last Post: 01-22-2011, 05:03 PM
