Results 1 to 3 of 3
    new xt m785b brake lever clicks
    The levers on my m785 brakes make a clicking noise when I pull them to about parallel with the bar which is when they firm up. It seems to happen both as I pull it toward the bar and as I release pressure at this same point. This is my first set of hydro brakes so I wanted to see if this is normal? Is this the servo wave making the noise? Oh, and I have not had a chance to ride with them. Thanks.
    El CicloPath!!!!!!!
    Nov 2012
    It night be the cam moving in the lever assembly. If the brakes are working as they should then it should be ok.
    Apr 2005
    Yeah, that's the Servo Wave Mechanism. When mine were new, they made a clicking sounds, sort of like a magnet on a fridge. After a summer of use, they don't make that sound anymore, but the lever still has that pop feel at that midpoint. You get used to it.
    Justin
    Salt Lake City
    2012 Specialized Stumpjumper FSR Comp 29
    2006 Specialized Allez Expert Double
  1. What's new on the xt m785B brakes?
    By ace42 in forum Brake Time
    Last Post: 07-17-2013, 04:52 PM
  2. Replies: 1
    Last Post: 11-06-2012, 06:47 PM
  3. elixer brake lever position, vs shift lever
    By thecanoe in forum Brake Time
    Last Post: 10-25-2012, 04:04 PM
  4. shift lever/brake lever position
    By thecanoe in forum General Discussion
    Last Post: 02-11-2012, 06:52 PM
  5. Replies: 1
    Last Post: 10-27-2011, 04:51 PM
